Automated Drawing Tool Not Working with Templates
jordan783ZS
jordan783ZS
When I use the "Automatic" mode for creating a drawing of a part with "From Scratch" as the template the system works as expected, but when I use an actual template the output page ends up being completely blank except for the title block. The part isn't even in the tree for the drawing.
jhackney1972
I cannot replicate your issue.  I am using a custom template I create over 2 years ago and the Automatic drawing function works as advertised.  You could attach your drawing template and the Forum users could check it out.
John Hackney, Retired
ClintBrown3D
Hi @jordan783ZS
Does your template contain placeholder views? If so, the automation will treat it like a “Smart Template” & ignore any automations.
to check, open your template, delete all sheets (except the first one), delete ALL browser nodes and placeholder views. Save this template (give it a new name for automations).
EDIT: Have a look here for more info on templates.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
jordan783ZS
Ah that would explain it, our template does indeed have placeholder views in it. However, doesn't having no nodes also mean that we won't be able to include things like a parts list in the template?
ClintBrown3D
Hi @jordan783ZS
For Drawing Automation, you set this up in document settings, there is a new "Automation" tab.
Clint Brown
