AutoCad Fusion can not be uninstall
danielaj
Observer Observer
danielaj
Observer
Observer
Good morning,
I´m writting about problem with program AutoCad Fusion 360.
This program doesn´t work. The problem is that it can not be uninstall. The mistake is attached below.
It would be very gratefull if you will help me.
Daniela Kattauerova.
TheCADWhisperer
@danielaj
Did you mean Autodesk Fusion?
danielaj
Observer
Observer
I am so sorry, it is my fault.
Yes, I mean Autodesk Fusion.
I installed AdAccess Installer before this problem. It could be main
problem. But I don´t know how I can uninstall it.
RajkumarIlanchelian
@danielaj Please try below steps to install Fusion.
1. Make sure that Fusion installer is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
danielaj
Observer
Observer
Thank you very much for your help. The problem was solved and program was
uninstall.
Have a nice day.
Thank you very much once again.
Daniela.
