Auto rotates and zooms in from start up
tbarber87
tbarber87
Whenever I start fusion 360, the entire program immediately starts to rotate and zoom out. I'm not sure why it would be doing this. I looked to the forum for answers - tried to adjust certain preference, set orbit points, restart fusion 360 and computer. If someone could help me as soon as possible that would be greatly appreciated!
It should be noted that I used this program prior to leaving for vacation a few weeks ago and did not experience this issue. I came back today and it has continued to do this.
Included is a screencast of the issue
TheCADWhisperer
Are you using a 3DConnexion device?
If so, does the behavior persist if you unplug the device?
If so, I would run Calibrate.
tbarber87
I am only using a mouse
jhackney1972
Disconnect your mouse and start or restart Fusion 360 to be sure there is not a stuck button or short in the mouse sending the command.  If you have a spare mouse, try it.
John Hackney, Retired
tbarber87
  • I disconnected my wireless mouse and restarted Fusion 360 with my laptop trackpad (I am using a remote desktop at the moment, again it has worked fine in the past), did not work. I repeated the steps again with a spare hard wired mouse and again did not work.
