Auto dimension in drawing space not functioning
jonathanYY8UL
jonathanYY8UL
Whenever I go to use the auto dimension feature on a drawing the dialog box appears for a split second and then goes away before I can even navigate to it. Even in that short time that it opens there aren't any options showing in the box. Anyone else have this issue?
Jon
-KyleWilliams-
Hey @jonathanYY8UL
I've tried this with existing as well as new drawings using various parts and templates and I'm not able to replicate.
Are you able to add some details as to your workflow when encountering this issue? Operating system, graphics card templates and the dataset are all helpful details if you can provide them.
If sensitive you can send them directly to me kyle dot williams @ autodesk dot com
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
mohammed.aliTDPXK
Hello @jonathanYY8UL ,
It seems you are clicking on Auto dimension button for sheet which is an assembly sheet with ISO views, these are basically the first sheet of Main assembly or sub assembly ISO sheets
  • For sheet which has ISO views i.e for main assembly or sub assembly sheets which has ISO view sheets we dont add any dimensions using Auto workflow and you will not be able to use the Auto dimension on these sheets. Also we dont show the Auto dimension recipes for Animation sheets.
  • For other sheets we get the Auto dimension dialog to display recipes.
Let me know if this helps, if not please share the model and sheets for which you are not seeing the recipes.
Thanks.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
