Assign mass to a component
p_riggs
Observer Observer
p_riggs
Observer
Observer
I've seen a few people ask if it's possible to assign a mass (and centre of gravity) to a component, overriding its calculated properties, and the answer always seems to be 'no, use a custom material and calculate its density to give your component the right mass'.
This seems like an awkward hack to provide a very simple feature. The use case is something like this:
I'm modelling some existing component, and I want to create a simple placeholder for it, with the correct mass. I know the mass, I know the external dimensions, this could be a straightforward task. But the workaround requires that I do some calculations to get the density right, and then hope that the CoG is in the right place, because if it's not, I have to modify my placeholder design to hack that too, and then recalculate density. Then if I modify my placeholder, I must go through the process again because changing the geometry changes the mass.
Can I bump this as a feature request? Thanks.
jhackney1972
Your suggested change to the Fusion application will probably never happen because of liability concerns.  If you create a artificial mass and center of gravity for a model and down the road someone uses them for say a lifting point and rigging.  When the lift is executed the load swings wildly due to a miss calculation of the center of gravity and the rigging breaks hurting someone, then You can expect to be sued for negligence.  Autodesk is not going to add a feature that would allow anyone to make the same mistake as they would then be subject to being sued.
John Hackney, Retired
TrippyLighting
This can be done in other CAD applications!
TheCADWhisperer
Can do it in Autodesk Inventor Professional.
Pretty standard practice - for example, you get a sub-assembly valve from a vendor that is just a shell of the geometry rather than the complete geometry.  Override the mass so that when used in your assembly has correct properties.
A variation of this question came up on the Inventor forum this morning...
https://forums.autodesk.com/t5/inventor-forum/weight-calculation/td-p/13428740
