Assembly in ground while in Render Mode
I'm relatively new to Fusion 360 and I've just completed my first assembly. I was trying to render the object and after getting the appearance to my liking, I realized the object is half way through the ground. I originally started modeling it using the origin as a way to cut it into 4 parts but have since moved the object above the x-axis. Is there a quick fix for this I haven't realized? Also is there a basic how to for creating renders? Any help would be great!
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
You can change the position of the ground plane by adjusting the "Position" under scene settings.
As for learning materials, here is a Fusion Fridays video about rendering that I think is pretty good!
Cheers,
Karina
