Assembling 3D pcb into case results in weird behaviour
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a PCB that I have exported from Autodesk Eagle using fusion link, before I updated fusion recently I was able to assemble the PCB into a case and all the components stayed in place, now when I try and use the joint command it only does a joint to a single layer. I've noticed that the way PCBs are imported into fusion has now changed with it seperating out individual copper and FR4 layers. I can't make a ridgid group of everything like I sometimes do with pesky step files. It doesn't make a difference whether capture design history is on or off on the assembly.
Version: 2.0.9642
Platform: macOS 10.15.6
