art college student here
i cant save to stl.
the whole program shuts down when i just ask to save to stl.
as a student... consistency is so important. you guys keep messing with fusion like a middle schooler in autoshop. just hammmering things and stripping threads. can you guys stop with the updates and just make a legacy. or a stable and just stick with it? im moving over to onshape.
jhackney1972
Open your model, select the body in the browser and right click.  Use the Save as STL command in the list.
If this does not work for you, attach your Fusion 360 model to your post and let others take a wack at it.  If you do not know how to attach your Fusion 360 follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
