Arrange function stoped working
Pabiuro
Pabiuro
I have a problem with arrange function. Pop up doesn't show either in design nor manufacture enviroment and it was fine until yesterday. After that failed attempt to use arrange fusion starts to have problems with other funcions (selection doesnt work etc.) and sometimes closes without any notification or I have to restart it. I've tried to reinstall it, turn off/on many times but nothing helps - error persists. I can edit old arrange functions but can't create new. I don't remember how but I was able to open arrange popup but without preview and ok button. But another option is to choose it from menu without success and then use that right mouse button wheel to use last function. It works "ok" but I cant pick any object or plane.
Didn't install new plugins and strangly reinstallation didn't help but still it looks like internal fusion app error. Can't share files here so I'll PM someone from autodesk support when you will answer.
Pabiuro
is there anything you can do? I can't work without arrange function.
jhackney1972
The Arrange command is working fine for me.  Normally when dialog boxes do not show up correctly is due to your graphics card drivers not being up to date or your graphic settings not set correctly.   Take a look in your Preferences and try another graphics driver.  I use the OpenGL settings purely because I use that type of card.
John Hackney, Retired
Pabiuro
Changed it, restarted fusion 360 and it is still not working. Anyway now if I try to use arrange function, popup doesn't shows (as always now) and then try to use last used function (which is arrange) from wheel, fusion just closes without warning and asking to send report.
Pabiuro
Found solution and next hint what could have happend. If I use arrange function from top bar list (then pop-up doesn't shows) then using wheel (LMB wheel) I cancel it annnnd then I use it one more time using last used function from wheel it works! So it looks like somehow my fusion 360 top bar was bugged. Funny thing, now it is working every time even from top bar and after restarting fusion.
Before that I've changed drivers to directx11 (from opengl) and I had closed screencast but it started to work after I did procedure above. It's fixed for now, strange bug.
I'm not sure about that but first time it could occure after I've tried to arrange on origin plane. I've tried to replicated that but I couldn't for now.
