I would like to report that the Arrange command is missing from the Modify menu when editing a Manufacturing Model in the Manufacturing Environment. As you can see in the screen capture, I have used it before in one of my file since it appears in my Timeline. If I try to create a different arrangement, the Arrange command does not appear under the Modify menu as it had before. If I type "S" and search from the command, it also is missing. If I return to the Design Environment, I do find the command as I have always.
Also, if I use the Arrange command in the Design Environment, it works just fine with one exception, it does not "Move" the components to the envelope, it copies them unlike it has in the past. It does not add the extra components to the Browser but it makes it difficult to determine which ones fit the Arrange and which ones did not. In this simple example, I can count but in more complex situations it may be an issue. You can see the issue in the attached screen capture.
Thanks for your efforts to pass this along to the Fusion 360 application group.
Copying Rather Than Moving
Arrange Command Missing
John Hackney, Retired
