Arrange Feature doesn't move objects anymore (issue)
nolanpeet
Observer Observer
Message 1 of 9
nolanpeet
Observer
Observer
I'm trying to arrange my parts on the floor, when i press arrange, i get a nice auto-preview of what it should look like, but then when I press ok, it just copies the pieces but doesnt move them to the square. I was using arrange earier today with no issues (up until i tried arranging on a sketch, which seemed to break everything) WHAT DID I DO??
Replies (8)
Message 2 of 9
jhackney1972
Without your model, there is very hard to help.  Please attach it.  If you do not know how, open your model in Fusion 360, select the File menu, then Export and save to your hard drive.  Attach it to a reply email using the attachment section.
John Hackney, Retired
Message 3 of 9
michaelFV8FJ
Observer
Observer
Hello everyone, I have the same problem as described above.
Enclosed is the file.
Many thanks in advance
Message 4 of 9
jhackney1972
You only have one component in your model.  I duplicated it a couple of times, then arranged them in the indicated area.  It works fine for me.  I broke the external file link and exported as a F3D file.  It is attached.
Message 5 of 9
michaelFV8FJ
Observer
Observer
Okay, but the problem is that here, for example, the part has been duplicated 3 times, but now 6 parts are displayed after arranging.
Message 6 of 9
jhackney1972
I see your point.
Message 7 of 9
carl.j.barker
Go into preferences and uncheck the Automated arrange in under preview features. This gets back to the original functionality.  But I recommend learning the new in case the change becomes permanent.
Message 8 of 9
dstommie
Community Visitor
Community Visitor
This fixed the issue for me, thanks.
Commenting mostly to state that this change is not my preferred outcome, and I hope that it does not become permanent. Or if it does there is an option to hide or move arranged components.
Message 9 of 9
walter.maguire
Community Visitor
Community Visitor
I am having the same issue.  The problem is that when I try to generate a 2d profile for laser cutting it won't recognise the second copies that are generated in the "Arrangement".
