Areas selected for extrusion don't turn blue
valentino_pi
Observer Observer
valentino_pi
Observer
Observer
Good morning everyone.
Since the last upgrade, whenever I try to extrude a new body or modify an existing one, the selected areas of the sketch don't turn blue as they did before, even if I see that they are being counted. I can get an idea of what part are being extruded only if I then select an height for the extrusion.
Can someone help me solve this problem?
Thank you
g-andresen
construction lines do not form profile contours.
Change them to solid lines
1. via sketch palette
2. select + shortcut x
günther
valentino_pi
Observer
Observer
thank you for your answer but that's not the case. there is a construction line close to the the line that closes the area.
As you can see, it does not turn blue not even with a simple closed square
g-andresen
1. change graphic driver selection > open GL ?
2. update graphic drivers
3. please share the file and mark the profile to extrude in a screenshot
File > export > save as f3d on local drive > attach to post
günther
valentino_pi
Observer
Observer
Thank you very much, changing the graphics driver to OPENGL solved the problem and selected areas are now turning blue again.
valentino_pi
Observer
Observer
Just a side note, the openGL solution worked on a pc with a graphics card in it, instead it freezes my notebook that only has intergrated graphics.
I've also tried DX9 but i had the same problem with it, not seeing the selected parts turbing blue
