Application Crash everytime soon after entering manufacture workspace
lachlan.dowd
lachlan.dowd
I created 90% of my model in Design. Switched to manufacture and created a model to manufacture. Edited the model and applied new Arrange (first time I have used it and should be a massive time saver). It worked correctly. Finished the edit on the model to go back to manufacture and then Fusion crashed.
Restarted and it was still in the edit mode. Managed to just jump back to design workspace to make additional changes to file. Went back to manufacture to redo my arrange but crashed within 1-2 seconds of switching workspaces.
Have tried at least 7+ times on my desktop machine (there should be crash reports that got sent as well).
Also tried the same design on my laptop with exact same crash.
Have since tried a very simple file with manufacture->arrange and it has been fine. Maybe the arrange is too complex in my other file?
Keen to get a solution/fix as would like to cut the design as soon as possible
I have attached the file that is causing the crashes.
Lachlan
shengrui.xiao
Hi @lachlan.dowd , Thanks for letting us know about this, we've created internal ticket TRUNFSN-2257 to investigate this issue, and apologies for the inconvenience.
I also uploaded the model, it will not crash in the latest build(2.0.9442), hope it will be useful to you.
