appearance of bodies is wrong in drawing
Nils_Schaeckermann
Nils_Schaeckermann
when using the 'shaded' display option in a drawing, some of the colors are wrong - as you can see in the attachments.
This is consistent on my system over different files.
To test/confirm this problem i created the test-file which is also attached.
Each body got assigned a different appearence.
The appearences used were 3x "Kunststoff - glänzend" (plastic - shiny/glossy) and 1x "Kunststoff - matt" (plastic - matte).
When creating a drawing of the file, you should (hopefully) see that some of the colors are interchanged...
Fusion Version: 2604.1.48
Windows 10 Pro 22H2 (19045.6332)
Nils_Schaeckermann
I just did a quick test again and added another body with the color 'yellow'... That body just became 'blue-ish'...
It seems that the RGB colors are interpreted as BGR...
green remains green - but blue and red are switched...
Nils_Schaeckermann
here is the example where i first noticed the problem...
It's really bad when doing a drawing of how to assemble a plug with colored wires...
really bad with wiringreally bad with wiring
bwalker145
Try changing the selected Graphics Driver under Preferences. This has corrected similar visual bugs for me in the past with Drawings.
Nils_Schaeckermann
Thank you - DirectX 11 solved this issue
