Also, if it helps, this is the full crash report:
Translated Report (Full Report Below)
Process: Autodesk Fusion 360 [46582]
Path: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Identifier: com.autodesk.fusion360
Version: 2.0.16490 (2.0.16490)
Code Type: X86-64 (Translated)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-07-06 09:28:14.0225 -0400
OS Version: macOS 13.2.1 (22D68)
Report Version: 12
Time Awake Since Boot: 1100000 seconds
Time Since Wake: 4379 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace ROSETTA, Code 0
rosetta error: Attachment of code signature supplement failed: 1
/var/db/*/3DconnexionClient.aot
Kernel Triage:
VM - pmap_enter retried due to resource shortage
Thread 0 Crashed:
0 runtime 0x7ff7fff4f524 0x7ff7fff4b000 + 17700
1 runtime 0x7ff7fff68970 0x7ff7fff4b000 + 121200
2 runtime 0x7ff7fff689f4 0x7ff7fff4b000 + 121332
3 runtime 0x7ff7fff5d2b4 0x7ff7fff4b000 + 74420
4 runtime 0x7ff7fff64884 0x7ff7fff4b000 + 104580
5 Rosetta Runtime Routines 0x1023bde88 ???
6 <translation info unavailable> 0x102427aa0 ???
7 dyld 0x2024448af invocation function for block in dyld4::JustInTimeLoader::makeJustInTimeLoaderDisk(Diagnostics&, dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&, bool, unsigned int, mach_o::Layout const*) + 84
8 dyld 0x2024441da dyld4::JustInTimeLoader::withRegions(dyld3::MachOFile const*, void (dyld3::Array<dyld4::Loader::Region> const&) block_pointer) + 234
9 dyld 0x2024447a8 invocation function for block in dyld4::JustInTimeLoader::makeJustInTimeLoaderDisk(Diagnostics&, dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&, bool, unsigned int, mach_o::Layout const*) + 509
10 dyld 0x20244b476 dyld4::SyscallDelegate::withReadOnlyMappedFile(Diagnostics&, char const*, bool, void (void const*, unsigned long, bool, dyld4::FileID const&, char const*) block_pointer) const + 138
11 dyld 0x202444580 dyld4::JustInTimeLoader::makeJustInTimeLoaderDisk(Diagnostics&, dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&, bool, unsigned int, mach_o::Layout const*) + 198
12 dyld 0x20243bde6 invocation function for block in dyld4::Loader::getLoader(Diagnostics&, dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&) + 1298
13 dyld 0x20243b28f dyld4::Loader::forEachResolvedAtPathVar(dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&, dyld4::ProcessConfig::PathOverrides::Type, bool&, void (char const*, dyld4::ProcessConfig::PathOverrides::Type, bool&) block_pointer) + 827
14 dyld 0x20242ad6b dyld4::ProcessConfig::PathOverrides::forEachPathVariant(char const*, dyld3::Platform, bool, bool, bool&, void (char const*, dyld4::ProcessConfig::PathOverrides::Type, bool&) block_pointer) const + 545
15 dyld 0x20243add3 dyld4::Loader::forEachPath(Diagnostics&, dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&, void (char const*, dyld4::ProcessConfig::PathOverrides::Type, bool&) block_pointer) + 251
16 dyld 0x20243b5d7 dyld4::Loader::getLoader(Diagnostics&, dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&) + 797
17 dyld 0x202442806 invocation function for block in dyld4::JustInTimeLoader::loadDependents(Diagnostics&, dyld4::RuntimeState&, dyld4::Loader::LoadOptions const&) + 435
18 dyld 0x20247160a invocation function for block in dyld3::MachOFile::forEachDependentDylib(void (char const*, bool, bool, bool, unsigned int, unsigned int, bool&) block_pointer) const + 107
19 dyld 0x2024240b7 dyld3::MachOFile::forEachLoadCommand(Diagnostics&, void (load_command const*, bool&) block_pointer) const + 245
20 dyld 0x202471482 dyld3::MachOFile::forEachDependentDylib(void (char const*, bool, bool, bool, unsigned int, unsigned int, bool&) block_pointer) const + 164
21 dyld 0x202442532 dyld4::JustInTimeLoader::loadDependents(Diagnostics&, dyld4::RuntimeState&, dyld4::Loader::LoadOptions const&) + 152
22 dyld 0x2024425b5 dyld4::JustInTimeLoader::loadDependents(Diagnostics&, dyld4::RuntimeState&, dyld4::Loader::LoadOptions const&) + 283
23 dyld 0x2024425b5 dyld4::JustInTimeLoader::loadDependents(Diagnostics&, dyld4::RuntimeState&, dyld4::Loader::LoadOptions const&) + 283
24 dyld 0x2024289b6 dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*) + 1260
25 dyld 0x202428281 start + 2289
Thread 1:: com.apple.rosetta.exceptionserver
0 runtime 0x7ff7fff4f614 0x7ff7fff4b000 + 17940
1 runtime 0x7ff7fff5b530 0x7ff7fff4b000 + 66864
2 runtime 0x7ff7fff5cf30 0x7ff7fff4b000 + 73520
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000022 x1: 0x0000000000000000 x2: 0x00007ff7fff7cb11 x3: 0x0000000000000800
x4: 0x00007ff7fff774ce x5: 0x0000000000000000 x6: 0x0000000000000020 x7: 0x00007ff7fff77a3c
x8: 0x00007ff7fff86000 x9: 0x3fc212554cd3008b x10: 0x0000000000000000 x11: 0x00007ff7fff8699a
x12: 0x0000000000000078 x13: 0x6e6e6f6344332f35 x14: 0x00007ff7fff6e980 x15: 0x0000000000000021
x16: 0x0000000000000209 x17: 0x000000010a41f427 x18: 0x800000010a41fb80 x19: 0x00007ff7fff7cb11
x20: 0x00007ff7fff7cb11 x21: 0x0000000110d7a000 x22: 0x0000000000000004 x23: 0x0000000110d7a000
x24: 0x0000000000000003 x25: 0x0000000000000001 x26: 0x0000000000000103 x27: 0x0000000000000000
x28: 0x00000002024273fe fp: 0x000000010a41f4e0 lr: 0x00007ff7fff68914
sp: 0x000000010a41f4c0 pc: 0x00007ff7fff4f524 cpsr: 0x40001000
far: 0x000000012c028e08 esr: 0x56000080 Address size fault
Binary Images:
0x7ff7fff4b000 - 0x7ff7fff7afff runtime (*) <f066db2c-ed38-3f37-8d21-81d15fa908fe> /usr/libexec/rosetta/runtime
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x202422000 - 0x2024b9fff dyld (*) <bba77709-6cad-3592-ab03-09d0f7b8610e> /usr/lib/dyld
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 18
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=2180K resident=0K(0%) swapped_out_or_unallocated=2180K(100%)
Writable regions: Total=168.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=168.5M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Rosetta Arena 4096K 2
Rosetta Generic 980K 242
Rosetta IndirectBranch 32K 1
Rosetta JIT 128.0M 1
Rosetta Return Stack 20K 2
Rosetta Thread Context 20K 2
Stack 8176K 1
Stack Guard 56.0M 1
VM_ALLOCATE 15.5M 6
VM_ALLOCATE (reserved) 11.5M 184 reserved VM address space (unallocated)
__DATA 112K 5
__DATA_CONST 48K 2
__DATA_DIRTY 16K 1
__LINKEDIT 736K 7
__TEXT 1472K 4
dyld private memory 512K 2
mapped file 8.2G 845
TOTAL 8.4G 1308
TOTAL, minus reserved VM space 8.4G 1308
Full Report
{"app_name":"Autodesk Fusion 360","timestamp":"2023-07-06 09:28:14.00 -0400","app_version":"2.0.16490","slice_uuid":"5e0a5c18-bef8-34d4-819e-2a619a85af59","build_version":"2.0.16490","platform":1,"bundleID":"com.autodesk.fusion360","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 13.2.1 (22D68)","roots_installed":0,"name":"Autodesk Fusion 360","incident_id":"3F34DB45-E14B-41B7-B2A3-731740B5508B"}
"uptime" : 1100000,
"procRole" : "Background",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "MacBookPro18,2",
"coalitionID" : 44565,
"osVersion" : {
"train" : "macOS 13.2.1",
"build" : "22D68",
"releaseType" : "User"
"captureTime" : "2023-07-06 09:28:14.0225 -0400",
"incident" : "3F34DB45-E14B-41B7-B2A3-731740B5508B",
"pid" : 46582,
"translated" : true,
"cpuType" : "X86-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2023-07-06 09:28:13.3485 -0400",
"procStartAbsTime" : 26829882193192,
"procExitAbsTime" : 26829897602751,
"procName" : "Autodesk Fusion 360",
"procPath" : "\/Users\/USER\/Library\/Application Support\/Autodesk\/*\/Autodesk Fusion 360.app\/Contents\/MacOS\/Autodesk Fusion 360",
"bundleInfo" : {"CFBundleShortVersionString":"2.0.16490","CFBundleVersion":"2.0.16490","CFBundleIdentifier":"com.autodesk.fusion360"},
"storeInfo" : {"deviceIdentifierForVendor":"6C326684-7EB3-5493-BB98-428905988587","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.autodesk.fusion360",
"crashReporterKey" : "BA760079-9483-BFE2-2E00-E7BD0B46E1C6",
"throttleTimeout" : 2147483647,
"wakeTime" : 4379,
"sleepWakeUUID" : "AD7F349F-3203-4470-A757-0715BCB9DAF7",
"sip" : "enabled",
"exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},
"termination" : {"flags":518,"code":0,"namespace":"ROSETTA","details":["rosetta error: Attachment of code signature supplement failed: 1 \n\/var\/db\/*\/3DconnexionClient.aot"]},
"ktriageinfo" : "VM - pmap_enter retried due to resource shortage\nVM - pmap_enter retried due to resource shortage\nVM - pmap_enter retried due to resource shortage\nVM - pmap_enter retried due to resource shortage\nVM - pmap_enter retried due to resource shortage\n",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":18},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":26740299,"threadState":{"x":[{"value":34},{"value":0},{"value":140703128079121},{"value":2048},{"value":140703128057038},{"value":0},{"value":32},{"value":140703128058428},{"value":140703128117248},{"value":4594254727441744011},{"value":0},{"value":140703128119706,"symbolLocation":242,"symbol":"__crashreporter_info__"},{"value":120},{"value":7957420063746895669},{"value":140703128021376},{"value":33},{"value":521},{"value":4467061799},{"value":9223372041321839488},{"value":140703128079121},{"value":140703128079121},{"value":4577533952},{"value":4},{"value":4577533952},{"value":3},{"value":1},{"value":259},{"value":0},{"value":8627844094,"symbolLocation":10,"symbol":"syscall"}],"flavor":"ARM_THREAD_STATE64","lr":{"value":140703127996692},"cpsr":{"value":1073745920},"fp":{"value":4467061984},"sp":{"value":4467061952},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":140703127893284,"matchesCrashFrame":1},"far":{"value":5033332232}},"frames":[{"imageOffset":17700,"imageIndex":0},{"imageOffset":121200,"imageIndex":0},{"imageOffset":121332,"imageIndex":0},{"imageOffset":74420,"imageIndex":0},{"imageOffset":104580,"imageIndex":0},{"imageOffset":4332445320,"region":"Rosetta Runtime Routines","symbolLocation":7816,"imageIndex":1},{"imageOffset":4332878496,"region":"<translation info unavailable>","imageIndex":1},{"imageOffset":141487,"symbol":"invocation function for block in dyld4::JustInTimeLoader::makeJustInTimeLoaderDisk(Diagnostics&, dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&, bool, unsigned int, mach_o::Layout const*)","symbolLocation":84,"imageIndex":2},{"imageOffset":139738,"symbol":"dyld4::JustInTimeLoader::withRegions(dyld3::MachOFile const*, void (dyld3::Array<dyld4::Loader::Region> const&) block_pointer)","symbolLocation":234,"imageIndex":2},{"imageOffset":141224,"symbol":"invocation function for block in dyld4::JustInTimeLoader::makeJustInTimeLoaderDisk(Diagnostics&, dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&, bool, unsigned int, mach_o::Layout const*)","symbolLocation":509,"imageIndex":2},{"imageOffset":169078,"symbol":"dyld4::SyscallDelegate::withReadOnlyMappedFile(Diagnostics&, char const*, bool, void (void const*, unsigned long, bool, dyld4::FileID const&, char const*) block_pointer) const","symbolLocation":138,"imageIndex":2},{"imageOffset":140672,"symbol":"dyld4::JustInTimeLoader::makeJustInTimeLoaderDisk(Diagnostics&, dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&, bool, unsigned int, mach_o::Layout const*)","symbolLocation":198,"imageIndex":2},{"imageOffset":105958,"symbol":"invocation function for block in dyld4::Loader::getLoader(Diagnostics&, dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&)","symbolLocation":1298,"imageIndex":2},{"imageOffset":103055,"symbol":"dyld4::Loader::forEachResolvedAtPathVar(dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&, dyld4::ProcessConfig::PathOverrides::Type, bool&, void (char const*, dyld4::ProcessConfig::PathOverrides::Type, bool&) block_pointer)","symbolLocation":827,"imageIndex":2},{"imageOffset":36203,"symbol":"dyld4::ProcessConfig::PathOverrides::forEachPathVariant(char const*, dyld3::Platform, bool, bool, bool&, void (char const*, dyld4::ProcessConfig::PathOverrides::Type, bool&) block_pointer) const","symbolLocation":545,"imageIndex":2},{"imageOffset":101843,"symbol":"dyld4::Loader::forEachPath(Diagnostics&, dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&, void (char const*, dyld4::ProcessConfig::PathOverrides::Type, bool&) block_pointer)","symbolLocation":251,"imageIndex":2},{"imageOffset":103895,"symbol":"dyld4::Loader::getLoader(Diagnostics&, dyld4::RuntimeState&, char const*, dyld4::Loader::LoadOptions const&)","symbolLocation":797,"imageIndex":2},{"imageOffset":133126,"symbol":"invocation function for block in dyld4::JustInTimeLoader::loadDependents(Diagnostics&, dyld4::RuntimeState&, dyld4::Loader::LoadOptions const&)","symbolLocation":435,"imageIndex":2},{"imageOffset":325130,"symbol":"invocation function for block in dyld3::MachOFile::forEachDependentDylib(void (char const*, bool, bool, bool, unsigned int, unsigned int, bool&) block_pointer) const","symbolLocation":107,"imageIndex":2},{"imageOffset":8375,"symbol":"dyld3::MachOFile::forEachLoadCommand(Diagnostics&, void (load_command const*, bool&) block_pointer) const","symbolLocation":245,"imageIndex":2},{"imageOffset":324738,"symbol":"dyld3::MachOFile::forEachDependentDylib(void (char const*, bool, bool, bool, unsigned int, unsigned int, bool&) block_pointer) const","symbolLocation":164,"imageIndex":2},{"imageOffset":132402,"symbol":"dyld4::JustInTimeLoader::loadDependents(Diagnostics&, dyld4::RuntimeState&, dyld4::Loader::LoadOptions const&)","symbolLocation":152,"imageIndex":2},{"imageOffset":132533,"symbol":"dyld4::JustInTimeLoader::loadDependents(Diagnostics&, dyld4::RuntimeState&, dyld4::Loader::LoadOptions const&)","symbolLocation":283,"imageIndex":2},{"imageOffset":132533,"symbol":"dyld4::JustInTimeLoader::loadDependents(Diagnostics&, dyld4::RuntimeState&, dyld4::Loader::LoadOptions const&)","symbolLocation":283,"imageIndex":2},{"imageOffset":27062,"symbol":"dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*)","symbolLocation":1260,"imageIndex":2},{"imageOffset":25217,"symbol":"start","symbolLocation":2289,"imageIndex":2}]},{"id":26740303,"name":"com.apple.rosetta.exceptionserver","frames":[{"imageOffset":17940,"imageIndex":0},{"imageOffset":66864,"imageIndex":0},{"imageOffset":73520,"imageIndex":0}]}],
"usedImages" : [
"source" : "P",
"arch" : "arm64",
"base" : 140703127875584,
"size" : 196608,
"uuid" : "f066db2c-ed38-3f37-8d21-81d15fa908fe",
"path" : "\/usr\/libexec\/rosetta\/runtime",
"name" : "runtime"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"source" : "P",
"arch" : "x86_64",
"base" : 8627822592,
"size" : 622592,
"uuid" : "bba77709-6cad-3592-ab03-09d0f7b8610e",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"sharedCache" : {
"base" : 140703213125632,
"size" : xxx-xxxxxxxx,
"uuid" : "4ca2b729-8206-3c63-badd-faa0225ab773"
"vmSummary" : "ReadOnly portion of Libraries: Total=2180K resident=0K(0%) swapped_out_or_unallocated=2180K(100%)\nWritable regions: Total=168.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=168.5M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nRosetta Arena 4096K 2 \nRosetta Generic 980K 242 \nRosetta IndirectBranch 32K 1 \nRosetta JIT 128.0M 1 \nRosetta Return Stack 20K 2 \nRosetta Thread Context 20K 2 \nStack 8176K 1 \nStack Guard 56.0M 1 \nVM_ALLOCATE 15.5M 6 \nVM_ALLOCATE (reserved) 11.5M 184 reserved VM address space (unallocated)\n__DATA 112K 5 \n__DATA_CONST 48K 2 \n__DATA_DIRTY 16K 1 \n__LINKEDIT 736K 7 \n__TEXT 1472K 4 \ndyld private memory 512K 2 \nmapped file 8.2G 845 \n=========== ======= ======= \nTOTAL 8.4G 1308 \nTOTAL, minus reserved VM space 8.4G 1308 \n",
"legacyInfo" : {
"threadTriggered" : {
"trialInfo" : {
"rollouts" : [
"rolloutId" : "63582c5f8a53461413999550",
"factorPackIds" : {
"deploymentId" : 240000002
"rolloutId" : "6246d6a916a70b047e454124",
"factorPackIds" : {
"deploymentId" : 240000010
"experiments" : [
"treatmentId" : "c28e4ee6-1b08-4f90-8e05-2809e78310a3",
"experimentId" : "6317d2003d24842ff850182a",
"deploymentId" : 400000012
Model: MacBookPro18,2, BootROM 8419.80.7, proc 10:8:2 processors, 32 GB, SMC
Graphics: Apple M1 Max, Apple M1 Max, Built-In
Display: Color LCD, 3456 x 2234 Retina, Main, MirrorOff, Online
Memory Module: LPDDR5, Samsung
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4387), wl0: Nov 30 2022 02:17:16 version 20.10.965.13.8.7.131 FWID 01-1251c18d
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
Thunderbolt Bus: MacBook Pro, Apple Inc.
