08:42 PM
I can't find an answer to this problem:
I'm designing a small cabin and I have surfaces that I need to extrude into plywood panels, rigid foam, etc. I start with a sketch where I draw out all of the rectangles of where each sheet will go on the roof. Then I want to extrude all of them by 24mm into individual components. However if I Shift-Click on each rectangle then extrude, it groups them all as a single component or a single body.
Is there any way to extrude each rectangle into its own component in one operation?
