Any easy way to create slats?
Hi All,
 I want to create a project where I will have repeating slats of a set dimension.
Is there an easy way ? At the moment I have created a component for each slat.
What I would love is to have my slats equal spaced over a surface while keeping the same dimension.
So lets say I have 10 slats , And want to spread them equally over a surface (with a gap between) how would I do this?
Many thanks
g-andresen
Please share a sample file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
I can't make the model , so I have attached a picture of something similar to my problem. Hopefully that explains it better.
davebYYPCU
Make one, pattern them with pattern on a Path, or Rectangular pattern, in one direction.
components or bodies will depend on your required outputs from Fusion.
Might help....
Rectangular pattern was just what I was after. Thank you
