Another Stuck upload issue
riaan.marx
Message 1 of 37
riaan.marx
Since yesterday my Fusion 360 refuses to upload files.
It just spins and spins forever:
and the job status window also does not progress any further:
and when I try to open the design from the project in the Data tab, there is an exclamation mark
and a message "the file is not available at the moment" for existing files. New files like the savetest I did above does not show at all, not even when viewing the projects on the web through a browser.
I have tried many of the solutions on the web:
Clearing cache
Manually clearing the queue
Created new project and new minimal design and tried to save
I even tried to repair, and ultimately uninstalled, deleted residual files and reinstalled Fusion 360.
I tried to collect diagnostic logs using the Help (?) button, but that produced this error:
Any help will be appreciated.
Kind regards,
Riaan
Replies (36)
Message 2 of 37
jhackney1972
I hesitate to send this webpage along to you as you will say you have already done everything is says.  I hope will will follow it to the last and be sure and execute the text command within Fusion 360, as you did not mention it.  It solved the same issue for me awhile back.
John Hackney, Retired
Message 3 of 37
RajkumarIlanchelian
@riaan.marx @Another one to test and fry is please check you upload and download speeds. Can you you post them here ?
if you can also restart your router and then your machine , I am thinking it will likely help all of these files move forward.
Collecting you disgnosriog files will certainly help too.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 4 of 37
riaan.marx
Internet speeds:
Message 5 of 37
riaan.marx
I also managed to get a diagnostic log. Attached.
Message 6 of 37
riaan.marx
Thanks John.
After a day and a half there is a lot I have tried, yes. But I am willing to give anything another shot here. If F360 has problems with something as trivial as saving my work, then I doubt it is the right solution for anyone. I am just a hobbyist, but imagine a architect/designing firm battling for 2 days to save their design?....At least for me the cost is only frustration and time. Anyway - let me go through those steps and see if it helps this time....you never know...
Cheers,
Riaan
Message 7 of 37
riaan.marx
Browsing through the log files myself I saw a lot of 404 results from API calls.
I noticed there is a network diagnostic test in the Service Utility. I ran this test to check if my laptop is blocking something...all seems to be accessible:
Message 8 of 37
riaan.marx
Browsing the logs, I found this section - not sure if it clouds or sheds more light on the issue:
20230515T064902 D 15460 LaunchDarkly: [C:\Windows\Temp\releaser-project\src\ldnet.c, 517] connecting to stream https://clientstream.launchdarkly.com/meval/eyJrZXkiOiJFWnJ1M0drTHROY3diVWNPelJUdExrbHYxWXM9IiwiZW1h...
20230515T064903 E 23712 Network failed request - response NOT OK:
URI:https://developer.api.autodesk.com/fhq/v1/spaces?type=FLC&fusionId=urn:adsk.fusion:scope:b5166870-9f...
...X-Request-ID: ContentBrowser_2178a32d-39f0-40dd-8a02-078bad7b0cba__GET_FLC_URN_GET_FLC_URN
...response: HTTP/1.1 404 Not Found
Connection: keep-alive
Content-Length: 375
Content-Type: application/json
Date: Mon, 15 May 2023 04:49:01 GMT
Strict-Transport-Security: max-age=31536000; includeSubDomains
X-Content-Type-Options: nosniff
X-Frame-Options: DENY
X-XSS-Protection: 1; mode=block
{"requestId":"ContentBrowser_2178a32d-39f0-40dd-8a02-078bad7b0cba__GET_FLC_URN_GET_FLC_URN","httpStatus":404,"detailedMessage":"Not able to find any SPACE with given search parameters","errors":[{"type":"errors","code":"FHQ-404","message":"Not able to find any SPACE with given search parameters","links":{"self":"https://developer.api.autodesk.com/fhq/v1/errors/FHQ-404"}}]} ThreadID: 23712, Function: Ns::Network::ReqUtils::logRequestError, Line: 320
20230515T064903 W .20836 FHQService: failed to get FLC URN, response code:
Message 9 of 37
riaan.marx
I launched "Fiddler" to monitor http traffic, and also found these API calls failing constantly with 404:
GET https://developer.api.autodesk.com/derivativeservice/v2/thumbnails/dXJuOmFkc2sud2lwcHJvZDpmcy5maWxlO... HTTP/1.1
Connection: Keep-Alive
Content-Type: image/png
Accept: image/png
Accept-Encoding: gzip, peerdist
Authorization: Bearer eyJhbG**********QA
User-Agent: Neutron/2.0.16009 (Windows NT 10.0)
x-ads-acm-check-groups: true
x-ads-acm-namespace: WIPDM
x-ads-ul-ctx-caller-span-id: 272d15f0e89d4337
x-ads-ul-ctx-head-span-id: 1-6461eb64-a5493b4eef884e758d1bbbe4
x-ads-ul-ctx-source: FUSION-P
x-ads-ul-ctx-source-version: 2.0.16009
x-ads-ul-ctx-workflow-id: sidepanel
X-Request-ID: ContentBrowser_1b211383-7aba-4ff4-a77d-aff1559e67d9___c2496f50-7875-41cf-a7c0-b3cb755509ed
X-P2P-PeerDist: Version=1.1
X-P2P-PeerDistEx: MinContentInformation=1.0, MaxContentInformation=2.0
Host: developer.api.autodesk.com
The response:
Date: Mon, 15 May 2023 08:20:56 GMT
x-ads-app-identifier: platform-viewing-2023.03.01.266.ce87a882d-production
x-ads-duration: 16 ms
x-ads-startup-time: Mon Apr 24 16:38:52 UTC 2023
x-ads-troubleshooting: The graph node specified by the urn/id was not found
Content-Length: 0
Message 10 of 37
riaan.marx
I checked my Network preferences on my profile and noticed that the proxy was set to "No Proxy" which is correct, but the Server Verification setting was set to not warn at all. I changed this to "Warn when accessing through an intermediate server" and then got this error message:
No I don't have a proxy server and my laptop is continually updated by our corporate update service, so that leaves anti-virus / protection programs. These have not been a problem in the past, but I will investigate.
Message 11 of 37
DieterP
Same here, since two days every upload stucks, exactly as described above!
Message 12 of 37
riaan.marx
Clearing the upload queue does not solve the problem. The next file you try to save just stalls again...
Is there a document or a set of steps on how to do a COMPLETELY CLEAN install?
Something like
1) uninstall the app normally
2) delete these files: .....
3) delete these registry entries: ....
4)  .....
5) run this clean--up tool or something
6) download a new installation and install the app as if it is a virgin installation
Message 13 of 37
DieterP
Problem is solved for me!
I figured out, that it only happens with two designs. I saved them both as new design files, now everything works like a charm!
Message 14 of 37
riaan.marx
Very happy for you DieterP.
Unfortunately my problem recurs even if I create a brand new file with a single cube drawn in it from scratch.
Message 15 of 37
RajkumarIlanchelian
@riaan.marx I am having our engineering team look at the log files you attached. Will update here as soon as I know more.
Autodesk Fusion
Join Fusion Insider
Message 16 of 37
RajkumarIlanchelian
@riaan.marx I had our engineering team look at the problem. We need your help to collect some more information.
1. Close Fusion 360
2. Reopen Fusion 360
3. Go to "View - Show text commands"
4. Set the option to Txt
5. Enter os3.verbose /on
What this does is enables to add extra logging of the Fusion 360 an uploads.
6. let Fusion sit for a few minutes and try to continue the uploads . In fact create a new design and try to save it to for an upload
7. After a few minutes - now can you please collect the diagnostics log files again please and attach it here?
This should help since there will be addition logs on what could be happening.
Autodesk Fusion
Join Fusion Insider
Message 17 of 37
riaan.marx
Hi @RajkumarIlanchelian ,
I tried to follow your simple instructions as close as possible, but to get the log files collected I had to restart the laptop etc. I also made some screenshots of the job status window and a few other windows in the process of collecting the logs. As a developer myself I know the steps followed and screenshots are valuable when debugging.
I included 2 files for you:
The steps with screenshots of what I did (the MSWord file) and the zip file with the logs.
Kind regards,
Riaan
Message 18 of 37
riaan.marx
Could the Server verification certificates issue have something to do with this?
Message 19 of 37
RajkumarIlanchelian
@riaan.marx Thank you for the logs, thank you for the detailed word document. really appreciate it. This will help a lot to understand what is happening.
(the Q drive should not have been deleted in this situation but that is OK 🙂 ). We will treat this as priority to see what is happening.
Autodesk Fusion
Join Fusion Insider
Message 20 of 37
RajkumarIlanchelian
@riaan.marx The certificate seems non suspect to this problem but I have to look into the logs. This one seems different but will know soon.
Autodesk Fusion
Join Fusion Insider
