Animation workspace missing
Hi there,
I can't find the Animation worspace anymore... any idea why ? How can I get it back ?
ryan.bales
Autodesk Support
Autodesk Support
First can you verify what version of Fusion 360 you are running?
Ryan Bales
Fusion 360 Product Support
Thank you for your interest in my issue.
I work on Fusion 360 Startup, version 2.0.6026.
We used to work on Windows 7 and recently upgraded most of our machines to Windows 10.
On Windows 7, I still have access to the animation workspace, but not on Windows 10 (All of them have the 2.0.6026 version of Fusion).
g-andresen
try this:
1. Peferences > Preview > enable "New UI" or
2. CTRL+ALT* Reset to default layout or
3. clean uninstall
good luck
günther
ryan.bales
Autodesk Support
Autodesk Support
That is an older version - we are on 2.0.6045 now. But animation existed then too. My guess is the install was incomplete and you'll need to reinstall.
Ryan Bales
You are both right. Clean uninstall + reinstall solved the problem.
Now, the tricky part is that all our computers are under a deepfreeze, that has an incomplete installation of Fusion - but that is our problem.
Thank you guys.
ryan.bales
Autodesk Support
Autodesk Support
Yeah it sounds like you have a lab install. That will take some time for sure.
Ryan Bales
