Animation storyboards missing in workspace
dcAWMGX
dcAWMGX
I have a strange problem, I recently created several storyboards to use in 2D drawings.
I created 2D drawings using the storyboards as usual.
Now i changed out a part and switched to the animation workspace to update the storyboards, but now all storyboards are gone.
The strange thing is that the 2D drawings still se the storyboards and show that they are referencing the latest version.
If i open an earlier version of the assembly the storyboards are visible.
This must be a bug.
Best regards
Dan
s.aartsR967Y
Hi!
I was looking for a solution for this as well, since the same thing just happened to me. Storyboards are gone from the animation space, but the drawings of those storyboards stay intact. References to versions seem fine. When I create new storyboards, they don't show up in the dropdown menu when I want to use those to create a new view (in the same drawing file). Any suggestions?
dcAWMGX
Is your 3D drawing a configuration? Then you just need to choose the correct configuration and the storyboards will show up.
