I have a question about Animating Joint Relationships. In my attached model I can currently get the desired motion when Animating Joint Relationships for the Revolute Joint for the Top Leaf on the top Bi-Fold Door Hinge between the 2 Door Panels on the left side of the door. This Revolute is in the Browser under Bi-Fold Door > Left (West) Door > Bi-Fold Door Hinge v3:1 > Joints > Revolute 1.
To get the model to this stage I have been concentrating on establishing joint relationships between the Top Bi-Fold Door Hinge and the other joints on the 2 door panels on the left side only. Joints have not yet been created for the other 2 Bi-Fold Door Hinges between these 2 panels or on the Mirrored panels on the right.
I also get the desired motion when I drag either of the 2 panels on the left outward in the Canvas. Although the right panel occasionally won’t drag out. As I said earlier, I can also get the desired motion when Animating Joint Relationships for the Revolute Joint on the top Bi-Fold Door Hinge. But this is the only joint I can animate to produce the correct motion. I am satisfied with this but ideally I would like the ability to animate any of the joints to produce the correct motion.
I can’t say all of the things I have tried over the past week or more to get the model to correctly animate from any joint. The last thing I did to get the model to this point was to create a Motion Link between the Top Leaf of the Top Bi-Fold Door Hinge & the Pin Hinge at the top-left corner of the left door panel. But after doing so, the right panel produces odd animation when the Revolute Joint for the bottom hinge leaf (Revolute 2) is animated. And I get no Preview Animation when I try to create a Motion Link between the Slider at the top and any of the Revolute Joints.
Can anyone please tell me just what is causing this? Is it because of the opposite directions of rotation for the Revolute Joints, or what?
Lenny
