Am I using xtickformat incorrectly?
tomherbig
tomherbig
I am trying to refine the x-axis labels in my graphs using the xtickformat command but something isn't working as expected.
For 2 digits after the decimal point, all is fine. I use
xtickformat('$%.2f');
which results in these correct axis labels:
For 3 digits after the decimal point, things are no longer as they should be. The command
xtickformat('$%.3f');
 now results in the following unwanted exponential notation in the axis labels:
However, fprintf with the same format specification still gives the expected result:
fprintf("$%.3f\r", 0.001)
$0.001
Am I using xtickformat incorrectly or is this a bug?
Tom
g-andresen
Are you sure you are in the right forum?
günther
tomherbig
Hi Günther,
No, I'm not sure. I haven't used the fora very much and don't really know what goes where. Would you have a suggestion as to where to post this instead?
Tom
g-andresen
I can't imagine in which function of Fusion 360 (CAD software) your request could occur.
günther
tomherbig
OK, that's very embarrassing! I had a problem with Matlab and mistakenly went to a Fusion 360 - probably because that was the open tab.
Thanks for being gentle with me 🙂
Tom
g-andresen
Who has not experienced something like this?
I wish you a good solution.
günther
