Almost Every Operation Causes Fusion to Freeze
tommyrennscot
tommyrennscot
I've got a bit of a weird one; I was recently creating a manufacturing file for a component and I hit a point in the file where almost no actions can be taken without Fusion 360 freezing and ultimately crashing as a result.
I have had a coworker test it on his computer with his account as well; does the same thing to him. I have rebooted and updated my station with no luck.
File attached; simply open it up and try to highlight one of the manufacturing operations or simulate the entire setup.
seth.madore
Turn off your In Process Stock. I was getting the same crashing with this file. I'll open a ticket to investigate
Seth Madore
tommyrennscot
Hey @seth.madore, I turned off in-process stock and still seem to get the same error. I will most likely just remodel and re-cam this part to see if that fixes it at this point. I am wondering if something got corrupt along the way.
tommyrennscot
@seth.madore nevermind. Turning it off in the ribbon was not enough. I had to also turn it off at the bottom of the screen. Thanks.
seth.madore
The other thing that you can do is turn this off:
It WILL increase calculation time, but that is what was causing the hang up
Seth Madore
