All objects and components are invisible. Can't extrude new scatches inside the file either
dukestercz
dukestercz
I've opened one of my projects as i wanted to iterate on design. However i can only see scatches.
I've tried to uncheck and check the visibility for all components and bodies. I've also deleted the cache, recomputed the timeline also made sure opcatiy is set to 100%. Even when i create new scatch and try to extrude nothing is happening. This only affects this file.
The only time i can see the objects is when i run section analysis Apart from this i can't see nor select anything apart from scatches.
g-andresen
disable Analysis
günther
TheCADWhisperer
@dukestercz
Are all of your sketches fully defined?
Do you have an blue lines or white dots in your sketches?
dukestercz
That did the trick. Thank you so much
dukestercz
Yeah i surely don’t have all sketches fully defined. This was my first cad project so i had no idea what am i doing. Not like i have an idea now but watched some tutorials ever since. Anyway. This did the trick thank you so much
