after last update i get an error runtime140.dll was not found.
jasonpollen0
Observer Observer
jasonpollen0
Observer
Observer
after the last update if i try to use post process it says vcruntime140.dll was not found  reinstall may fix this problem.  i tried a reinstall and i tried a repair from windows apps.  its not fixed it. any help would be great.
seth.madore
This is a known issue that we're currently working on a fix for. In the meanwhile, you're only option is to go to Microsoft and download the DLL for yourself.
It needs to end up here:
%LocalAppData%\Autodesk\webdeploy\production\<some latest version>\Applications\CAM360
Seth Madore
jasonpollen0
Observer
Observer
thank you for the fast reply. ill hold fire for the fix if i cant find it from microsoft. thanks again
jasonpollen0
Observer
Observer
i hope this helps. i wen there and downloaded this file and run it and it solved the issue without having to put the file in any complicated places.
Download Microsoft Visual C++ 2015 Redistributable Update 3 RC from Official Microsoft Download Cent...
