Additive - FFF Retraction not repriming
Eric_Schubert
Eric_Schubert
I'm not sure exactly when this problem started, but it's fairly recent.  In the Additive environment, I'm noticing that my prints no longer re-prime after retraction.  For example:
My retraction settings are very short, at only 0.4mm for direct extrusion.  My extruder retracts, but it does not appear it primes again as it resumes printing after a move or layer change.  It just resumes extruding once the nozzle comes back down, as if retraction was disabled.
I've tried updating my Creality post-processor, but that has not helped.  I've started totally new design files and imported my print settings again.  But this also has not helped.  Lastly, I even reinstalled Fusion 360, and that also did not fix the issue.
Retraction and re-priming worked just fine in previous versions, so I'm not sure what's changed to cause this issue.
I've attached an example file for reference.  I see the extruder retracting on layer changes or after completing infill on the base of this calibration cube.  But no priming after retracting is occurring.
jodom4
@lukas.fuhrmann can you take a look at this one?
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Eric_Schubert
@jodom4  and @lukas.fuhrmann
I was able to resolve the lack of retraction by reverting to Marlin 2.0.5.3, which is what I used prior to updating to Marlin 2.0.8.  I'm not sure what's up with the newer version, but retraction now functions correctly again.
I was able to replicate lack of retraction using Cura 4.9.1, as well.
So, this is not a Fusion 360 issue, this is a "Marlin not reading the retractions properly" issue.
lukas.fuhrmann
@Eric_Schubert thank you for the feedback and also for providing the resolution. Glad to hear that you could identifiy the issue (and that it is not our fault 🙂 ). Please be sure to post again in the future if you have questions or find any issues.
Best Regards,
Lukas
Lukas Fuhrmann
Product Owner Additive Manufacturing
