Adding to lines
Adding to lines
Adding to lines
I'm designing a sign for a client of mine and am having trouble getting lines to "connect". I used the offset command to get my spacing right and then followed that with the Fit Point Spline to make some adjustments and make it all look nicer. As you can see in the attached file, the outline of the nose won't connect correctly so it can be extruded... any help??
https://a360.co/36JryCn
TheCADWhisperer
file:
TheCADWhisperer
Am I missing something?
Your curve is (was) Construction linetype?
THANK YOU! I'm very new to this and obviously learning... forgot to change it.  thanks again!
