Hello! I am having trouble with this issue here. I have this engine assembly, where Im trying to transform the Rotational Motion into Linear motion. I made 3 joints between the crankshaft, the piston rod, and the piston cap, however, when I'm trying to Animate The joint relationship on the crankshafts rotation joint, the only joint that is doing something is the one between the crankshaft and the piston rod, the one on the piston rod and the piston cap is just static.
Video:
