4th axis simultaneous moves in Y axis when it shouldn't
eddwik26
eddwik26
I wanna be able to use the 4th axis (A-axis) simultaneous but Fusion 360 makes it run Y-axis when it should only use (A,X,Z) axis wich causes crashes etc, i will be posting the model im working with and the post processor i use.
Arun.rs
HI @eddwik26
Thanks for posting.
If the machine is capable of TCP mode (M128) then Y coordinate will taken care by the controller itself and if the machine is not able to perform TCP mode, you have to change like below.
1. Got to line number 263,
Change this :
optimizeMachineAngles2(0); // using M128 mode
To this :
optimizeMachineAngles2(1); // using M128 mode
Save the file and test the NC output carefully.
Regards
If my post answers your question, please click the 'Accept Solution' button. This helps everyone find answers more quickly!
Arun.RS
Senior Technology Consultant
