3d sketch fillet failure...
ivanthestupid
Message 1 of 13
ivanthestupid
Good day. I am still struggling with the basic operations in F360. There is a 3d sketch line sequence with 2 peak points, that need to be rounded. But the fillet op between the arc and straight line fails. Why on earth there should be a problem? Every single program can accomplish this easily. I have no constraints in this sketch, except for the coincident points.
Replies (12)
Message 2 of 13
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Message 3 of 13
ivanthestupid
Sure. There it is.
Message 4 of 13
g-andresen
Since there is no common plane between the elements, the fillet would be "virtually" bent in itself.
But this is not possible.
günther
Message 5 of 13
TrippyLighting
I would stay away from 3D sketch until you have the Basics down.
Message 6 of 13
ivanthestupid
What's the point of your statement? Fillet can also be defined as a bezier curve, having it's control points based on incoming curves tangents, and it would work like a charm. But of course you had to put your meaningless sentence here.
Message 7 of 13
ivanthestupid
This is actually possible in many other programs, it depends on how you define "fillet". I'd call it lack of functionality. But thanks anyway.
Message 8 of 13
TrippyLighting
The design you presented does not use a spline as a fillet. It uses an arc. That arc needs to be on a plane that coincides with the line the and the point the arc ends in. That stuff is better to control outside of a 3D sketch.
That is what I mean with "stick to the basics".
You can of course use a spline as  what is often defined in other CAD software as blend curve to be used as a fillet. This  would be one of the areas that actually would justify using a 3D sketch. However, such a blend curve, usually a 5-degree spline with G2 constraints at either end, needs two adjacent curve segments to blend between, not a curve/line and a point.
Both of the above can be done in Fusion 360. Both, fit point splines and control point splines (3-degree and 5-degree) are in the sketch menu.
Lacking aptitude and then having an attitude is not welcome here on the forum!
Message 9 of 13
ivanthestupid
Yup, assumingly, I had to extract all this information (I already know, btw) from your "Stay away from eating until you learn endocrinology". The point is: I know I can do it manually, but I asked for an automated tool, which is absent. Glad for your wounded pride.
Anyway it doesn't change the fact that message 5 is comletely unhelpful.
Message 10 of 13
TrippyLighting
In what exact post did you ask for an automated tool and what level of "automation" do you expect ?
If you use other CAD software, do you have a reference behavior you can demonstrate ?
Again, you presented a design and sketch that, mildly speaking, did not show a lot of promise.
Maybe show a bit more effort in your initial posts when you ask questions the next time.
Message 11 of 13
ivanthestupid
Yeah I am obviously going to waste my time demonstrating things to a person, who provided zero help. "Get gud" is never a good answer, so plz leave me, or write down some sophistry, i don't care.
Message 12 of 13
TrippyLighting
The "help" I provided in post #5 was exactly proportionally to the level of information you provided.
However, we are now at post #11 and, clearly, you are not at a level to discuss this with any level of sophistication.
So, yes, we're done here!
Message 13 of 13
ivanthestupid
- "The" help "I provided in post # 5 was exactly proportionally to the level of information you provided."
No it's not 🙂 guenther.andresen provided the valid answer for me, you're just sitting here, being the Captain Obvious and showing up your resentment and touchiness through baseless accusations for a half of a day. Keep us up to date 🙂
Srsly, the only reason i am still answering is because it's helluva fun.
By the way: every single question here is sooo perfect, ooooh.
