3D print quality
3D print quality
greenwoods1462
3D print quality
greenwoods1462
Hello
I have attached two files of two similar models.  One prints very smoothly, the other does not.  I am using the same 3D print command in fusion and not changing any parameters.  But just by looking at the vectors I can see that one is finer than the other.  Is there anything I can do differently?
Many thanks in advance
TheCADWhisperer
I didn't open your files (yet) but the first thing that comes to mind...
Edit: When I opened these - there is no assembly named smooth or rough.
Which one is which (the actual assembly names)?
greenwoods1462
i have attached two files, the S Scale boiler is the one that is a problem.  The production assembly comes up fine.  There are a few things to constrain, I am working on this.....
TheCADWhisperer
There are no curves in an stl file - only the straight line boundaries of triangular planar facets.
Increase the number of facets to make "smoother" representation of curved surfaces.
