36hr to recompute simple model on Mac mini m4 pro not finished?!!
someonesidea9F22F
Observer Observer
someonesidea9F22F
Observer
Observer
I tried three time to recompute simple model on Mac mini m4 pro with 64GB of ram and 10gb/s network card and every time fusion utilize 100% of CPU and 8.88GB of ram and it stuck at 84% recomputing forever and I had to force quit fusion because it never end last time I leave it for 1 day and half more than 36HR and it did not finish this is absurd and I cannot work like this. I remove fusion and reinstall it also I try to repair fusion, I tried to work offline nothing seems to work. I need a solution and my model is 3 sketches and 23 feature in the timeline ?!!! I wonder if I had to work on more complex model !!
jeff_strater
Can you share this simple model here?  Unless it is not so simple, it should be able to recompute in a reasonable time.  I can try it on my machine to see if I see the same thing.  It could be specific to the model, or your computer.
Jeff Strater
Engineering Director
someonesidea9F22F
Observer
Observer
first of all, thank you so much Jeff for reply and trying to help but unfortunately, I cannot share the model but I find out that pattern feature cross plate 60cm x 40cm x 0.25cm of 1/4" thread holes with offset -by (-0.1) for 3d print thread accuracy- and drift from both side is what takes fusion days to recalculate on m4 pro when I configure the plate from 16cm x 16cm x 0.25cm (with 361 thread hole) to 60cm x 40cm x 0.25cm (with 4293 thread hole) fusion keep 100% CPU for 2 days without finish computing. I wonder if I have complex mechanical model like a motor with different thread size and tons of parts that I need to have two or three configuration for it?!! or if there are another modeling method I should use to achieve my 3D print goals with fusion because I tried to not model the threads and then before sent the model to printer to model the threads and I have the same issue ?
g-andresen
Check your setting:
1. Features > try  Compute type "Optimized" or "Identical" > avoid "Adjust" !!!!
2. "Faces"  works fine
günther
TheCADWhisperer
@someonesidea9F22F
When your actual model is proprietary then make up a dummy file that exhibits the same behavior and attach that file.
TrippyLighting
@someonesidea9F22F wrote:
... I wonder if I have complex mechanical model like a motor with different thread size and tons of parts that I need to have two or three configuration for it?!!...
I assume you used modeled threads instead of cosmetic threads to create a 3D printable object. A model with over 300 modeled threads is a model with an enormous amount of geometry, as modeled threads are internally stored as NURBS surfaces. That is a complex model, as each thread geometry cannot be instanced but has to be stored as separate geometry.
g-andresen
I just tested it with modeled thread and offset flanks:
4500 instances
1. Features > Optimized = 36 s
2. Faces = 33 s
günther
System:
CPU I 7-7700 @3,6 GHz
