2D Contour not mechining full Pocket Chain selected
CNdove
Observer Observer
CNdove
Observer
Observer
Okay so context here, thoese four holes used to be roughed out before. However I changed and added to the drilling cycles before this opp which resulted in this error. I can go back up my version history and make the exact same changes and it doesnt cause this error, however i cant save that, only save as which i dont want to do. Any help would be deeply appreciate as I am getting quite cross over this.
daniel_lyall
Can you attach the model To attach a file Go to File -> Export and save as a .F3D Archive File and attach it to your next post, if you can not post the file you can PM it to me or say in your next post you can not post the file and one of the Guys that do NDA work will help.
Is this the titan 10m?
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
CNdove
Observer
Observer
Thankyou for looking the problem I'm having. Yes this is the M10 however as I am based in a country that uses Metric some of the dimentions of the model and all of the tools used are Metric in sizeing.
Tope the attached file is able to help!
seth.madore
It does appear that using PreDrill for your Plunge setting is causing the issue, more investigation is required. As an easy fix, change it to Plunge, but continue to select the Entry Points, it's still going to plunge at the specified location
Seth Madore
CNdove
Observer
Observer
Nice that fixed the problem, thankyou very much for your help in resolving this issue!
