1000 Fillets
1000 Fillets
garrettpaulmorgan
1000 Fillets
garrettpaulmorgan
Community Visitor
Community Visitor
I have a design in fusion that has a very large quantity of corners that all need to be filleted to the same radius. Also, the thicknesses of these parts are all the same and they are in the same drawing.
The design is similar to plasma cut letters, and i need to fillet all the outside corners to .0625. Is there a faster way to select hundreds of specific edges based on min/max angle and thickness rather than individually selecting them all?
Thanks so much!
g-andresen
take a look at Rule Fillets
günther
jhackney1972
@g-andresen suggestion works great.  One setting you need to use, to make it work easily, is shown in the attached graphic.  If you have this set and Window Select the letters you want it works well.  Window select is left mouse click and hold and drag from left to right.  You could use Crossing select as well, your choice.  I personally would recommend that you do smaller groups, say a word at a time, to make it easier to find failures if they occur.
You will be using Fillet - All Edges option.
John Hackney, Retired
