Grbl laser post
Grbl laser post
the PWM-value for GRBL-controlled machines (laser-power-output) is defined by using the s-value in the gcode. At the moment this value ist at 255 which means about 25% power. This should be easier to edit.
Greetings from germany
Michael
7 Comments
AchimN
GeorgeRoberts
Good Afternoon Michael,
The power setting can be changed by modifying the 'laser power' property in the post dialog as shown below:
Would you like to have a different power setting for each cutting mode?
m.luessem
Thank you George for you advice, I didn't recognise the opportunity to edit this value. Perhaps for newbies it would be easier to make a scale from 0-100% which edits the s-value from 0-1000
GeorgeRoberts
Thanks for the recommendation, I will look at adding that functionality. I have also added properties so you can adjust the power value for etching and vaporize cutting.. That should appear in the library soon
AchimN
ArjanDijk
I'm testing with this post and a previous comment that M5 is not implemented for multiple shapes. For now this is the result of a few shapes:
(1001)
(draaienpoot)
G90 G94
G17
G21
(2D Profile1)
G54
G0 S255 M3
G0 X73.938 Y28.376
G3 X93.938 Z0 I10 F1000
G3 X73.938 I-10
G0 X50.938
G3 X70.938 I10 F1000
G3 X50.938 I-10
G0 X27.938
G3 X47.938 I10 F1000
G3 X27.938 I-10
G0 X24.938
G3 X4.938 I-10 F1000
G3 X24.938 I10
G0 X0
G1 Y56.752 F1000
G1 X100 Y56.753
G1 Y0
G1 X0
G1 Y28.376
G1 S0
M30
ArjanDijk
Appears I was wrong. If you have the new GRBL with laseroption, it does laser on on G1/2/3 and laser off on G0. So this is only valid for new versions. Old versions still need M5 to turn laser off, but there is no reason anyone should not update their setup. I'm testing along.
