We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Select All button
Select All button
In the tablet view, it would be nice to have a "Select All" button when doing batch operations with serialized products. Especially important if there are 20+ items in the operation and all 20+ are good (as determined from the previous quantity screen). I would also like to use it to "select all" and then go back to remove the couple items that failed.
2 Comments
andrade_david
Hello @jtarnai , thank you for your idea.
If I understand correctly, this "select all" would be applied to select all serial numbers that are available when checking out of an operation. If that is the case we have an alternative, which is tapping and holding on the first serial number, and then selecting the last one. This will select all the serial numbers between the first and last one selected.
Let me know if we're in the same page
andrade_david
Status changed to: Archived
Hi @jtarnai
I marked this idea as Archived because it is already possible to be done today. If needed, feel free to reach out to me or to the support team (on the bottom right corner of Fusion Operations) to know more.
Thank you
