Management of duplicated serial number generation
When we use a serial number, meaning that each unit produced have only one ID associated, the system shouldn't allow to generate a production record on the same operation if the serial number has already been generated.
It happens by human mistake when workers are typing the serial number. If this happens the system must send a message to the operators inserting the production indicating the SN has already been generated for that operation (the system must help the operator and work as poke-yoke). This is important to change, beside all described mentioned above, if you enter this repeated operation the system count it as (quantity) produced and therefore the operators are unable to record the reality of the shop floor.
6 Comments
andrade_david
Hello @qualidadeJKJCN
Thank you for your idea. This should be possible by enabling the setting " Do not allow to select SNs already produced when selecting SNs in production". Can you try it and let me know?
Post edit: The idea has been edited, as the problem was related to the generation of the SN, and not when selecting the SN in following operations. The setting mentioned above does not prevent serial numbers from being generated twice today.
andrade_david
Just a small note, I've edited my last comment as I mentioned the incorrect setting at first. Let me know if this works!
qualidadeJKJCN
Hello David that setting was already selected, let me know further steps. ThanksSerial numbers preferences.jpg
qualidadeJKJCN
in fact it happens again today. Thanks in advance for your attention
andrade_david
Hi @qualidadeJKJCN
Your screenshot has low quality and I cannot see its data. Can you send it on a private message so I can take a closer look?
andrade_david
Just sharing that I've edited your idea @qualidadeJKJCN, to better reflect that the idea refers to the serial number generation, and not the selection of the SN during the following operations.
