When creating products if you move to a different tab without manually saving then you have lost all the work you have completed. For example, if you create a product and then an operation, if you do not go back to the product tab and save then you have lost all your work. there should be a "pop up" window if the system recognizes that you have not saved your work before moving to another tab.
