Fusion Manufacture
Z moving to below component on export of gcode
7 REPLIES 7
Message 1 of 8
tinkercad3PS8N
236 Views, 7 Replies
Hi
New to F360. Happy with the design etc, but can't work out why the gcode resorts to cutting from below the component! When I simulate on F360, everything looks good. When I export to .nc and check it on a simulator the gcode sends the router to below the component.
The cut is the right way up i.e the end result is correct, but the cutter starts from below the piece.
Tried numerous tests but result is always the same.
Any help very much appreciated.
C
7 REPLIES 7
Message 2 of 8
Could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 8
Very much appreciate your help.
Clive
Message 4 of 8
Apologies, applied to wrong message.
Clive
Message 5 of 8
What post processor are you using?
Seth Madore
Message 6 of 8
Hi Seth
I'm using 'WinPC-NC / winpc-nc'
Cheers
Clive
Message 7 of 8
That post processor has a default setting of "reverse Z axis". I think that post was written for a machine that considered anything above the part to be a negative Z value, and anything into the part was a positive move.
If your machine isn't setup like that, change this setting:
Seth Madore
Message 8 of 8
Thank you so much Seth for your accurate solution. Tried and tested.
Very much appreciate your speedy response.
Very kind regards
Clive
