Announcements
-Z min in G code?
jgaertner
-Z min in G code?
jgaertner
Hello Form,
I am new to Fushion and learning G code.I am trying to create an engraved feature with a 45 degree engraving tool in a practice piece of MDF. I have created my G-code but on line 6 I get:
(T1  D=0.487 CR=0. TAPER=45DEG - ZMIN=0.6546 - CHAMFER MILL)
If I try to run the code on my CNC machine after zeroing my tool height on the work piece the code is executed above the work piece? I suspect it has something to do with this - ZMIN?
It is still unclear to me how to set the depth of cut I want in Fusion 360? I have read the Paramters section of the on line manual but this aspect does not make sense to me.
Any help would be appreciated. Code is attached.
HughesTooling
That line is just a comment not read by the control and the minus is just between the different info on the line, it actually show the minimum Z is +0.6546
Here's the first few lines from your file.
(* Tormach PathPilot Mill Post Processsor      r20160408 *)
(BSA-SIGN-SWALLOW-ENGRAVING-SAMPLE-5)
N10 G90 G54 G64 G50 G17 G40 G80 G94 G91.1 G49
N20 G20 (Inch)
N30 G30
(ENGRAVE3)
N50 G30
N60 T1 G43 H1 M6
N70 S5000 M3 M9
N80 G54
N90 G0 X1.7427 Y1.4954
N100 G0 Z1.2546
N110 G0 Z0.8546
N120 G1 Z0.6546 F39.4
N130 G1 X1.7209 Y1.4883 F23.4
N140 G1 X1.699 Y1.4815
N150 G1 X1.6769 Y1.4751
If you look a line N120 you can see the Z is 0.6546, if the top of your job is zero then this is not going to cut. I guess you have the origin in the setup wrong or different to the setup on the machine. Your best bet is to export the f3d file and attach so someone can help.
Mark
Mark Hughes
Owner, Hughes Tooling
jgaertner
Thanks! So much! That was what the problem was, I had selected the wrong Zero Z when I was doing the set up. It was hard to see the right point to select. Now I will know, next time how to correct this issue. The part ran perfectly!
Jgaertner
