Z Height CAM Code is wrong; Too deep
I am having an issue with Z height that I have never experienced before and can't figure out why it is happening. I am using Fusion 360 and Mach 3. I have a 19mm work piece that I have a 3mm pocket recessed into the face. When I setu up the cam and export the GCODE the Z heights are deeper than the 3mm cut. I have tried 2D Adaptive Clearing and Pocket. I get Z -3.5mm instead of 3mm.
FYI I have done the Mach 3 stepper motor calibration and it is accurate.
(MOUNTING PANEL FINAL 529 - PANEL RECESS 3MM POCKET)
(T1 D=6.35 CR=0. - ZMIN=-3.5 - FLAT END MILL)
G90 G94 G91.1 G40 G49 G17
G21
G28 G91 Z0.
G90
While I am asking I have been unable to figure out why the G28 G91 Z0. always goes to zero. I have just gotten used to manually editing the file to Z5 to keep from messing up the work piece.
