Z axis cutting uneven
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My models look good in simulation but my actual CNC carve is coming out with uneven parallel passes. My Step Over is fine on a .125in bit I'm only stepping over .35 mm and only cutting 2mm deep. My passes are smooth but there does seem to be a bit of play in my Z axis assembly, I'm using a stock X carve Z axis. I can't seem to eliminate the slack in the assembly. Anyone else run across this problem?
Wayne Dean
Link copied
