Fusion Manufacture
Y axis lathe tool orientation issue
2 REPLIES 2
jamie_xbox
175 Views, 2 Replies
Good morning folks I have a newbie question for you. I am attempting to mill flats on a haas st25y with the radial live tool. Ok here is the issue. I can not get it to change my tool orientation without it changing my axis. I need to be perpendicular to the x plane and mill in zy with the end of my endmill. If i get the tool perpendicular to the part then the axis changes. I need the xzy to stay the same and just change the tool orientation. Any help would be appreciated.
2 REPLIES 2
seth.madore
in reply to: jamie_xbox
Changing the tool orientation WILL change the visual display of the axis (in the toolpath), this is intended. Are you having issues at the machine itself?
Seth Madore
jamie_xbox
I was just coming back to say I realized when I posted the program that it was indeed cutting in yz as intended. My fault I got a little ahead of myself.
