Y AXIS LATHE CONTOUR MACHINING TOOLPATH
evanALSJ8
evanALSJ8
Hi guys,
I'm having trouble working out what tool path to use in the attached model to machine the pockets out of this part. I would have thought 2d contour would have done the trick but can't get it to work.
I plan on using the flank of the endmill to come in from the side in multiple passes at full depth.
Any help would be appreciated thanks.
a.laasW8M6T
Hi
Try this
seth.madore
Thanks for the video @a.laasW8M6T! I think the one thing I would do (and that's quite likely just my personal preference) is that I would actually make a joint to bring the part to the "document origin", I find that my SpaceMouse rotates around that point instead of the visible model on-screen.
Seth Madore
@seth.madore , that is probably a better idea, I did think of that after I posted the Video.
The issue with the stock silhouette not being aligned to the actual stock(but to the origin) I think is quite old or is it also related to CAM-56718 at all?
evanALSJ8
@a.laasW8M6T I cannot thankyou enough. As you said it was drawn in a weird orientation.
Got it running straight away and out the door. Did not expect a detailed video!!🙏
seth.madore
Separate issue
Seth Madore
