Fusion Manufacture
WORK COORDINATE SHIFT
2 REPLIES 2
dmilichnikov
148 Views, 2 Replies
Hello! My cnc lathe (Samsung sl20mc, fanuc 0i-td) using work coordinate shift offset (G54 not needed). Right now I have delete each g54 by hand, if I miss one, machine will crash. Is it way to setup it in Fusion 360 to not have G54(55...) in post?
Thank you!
2 REPLIES 2
seth.madore
in reply to: dmilichnikov
Yep! What post processor are you using? (I assume the Fanuc turning post)
Give this new Fanuc post a try. I've modified lines 1077 thru 1080 to omit the call for the WCS.
Seth Madore
dmilichnikov
in reply to: seth.madore
Thanks! This works very well!
