Why is my tool showing up as "UNSPECIFIED"
landcrush
landcrush
boopathi.sivakumar
Hi @landcrush
Its usually the description of the tool,
if you could let me know what in there then we can check
Boopathi Sivakumar
Senior Technology Consultant
landcrush
Thanks so much for responding. So... In my description field, this is the entry:
51472 Solid Carbide CNC Spiral 'O' Single Flute, Aluminum Cutting 1/16 Dia x 1/4 x 1/8 Shank x 1-1/2 Inch Long Up-Cut Router Bit
obrienm
Hi @landcrush ,
We've seen this sort of issue before where quotation marks in the tool description cause it to appear as 'UNSPECIFIED' (the internal task id is CAM-26533).
Does removing the quotation marks around the 'O' in the description in the Tool Library fix the issue for you?
Mark O'Brien
Senior Software Engineer
landcrush
Yes, that solved the problem! Thanks so much, it was really messing with my sense of order...little OCD going on with me here..
