Fusion Manufacture
Why is everything a chamfer?
3 REPLIES 3
bob_h81
150 Views, 3 Replies
3 REPLIES 3
seth.madore
in reply to: bob_h81
There is a known bug (CAM-46909) that is causing this. In our testing, this happens when you select a bunch of toolpaths and then try to edit the name of one while the others are selected. Can you confirm that these were the steps you took leading up to this?
Seth Madore
bob_h81
Can't confirm. I didn't edit any toolpath names.
I did, however, do a copy/paste of the operations, from one part, to a similar part. The original toolpath names are correct. The pasted toolpaths names are all "chamfers".
mattdlr89
in reply to: seth.madore
@seth.madore I don't believe the problem you describe is a bug. This is similar behaviour to how renaming files/folders works in Window.
