Fusion Manufacture
Why are newly created tools automatically given Tool #1?
4 REPLIES 4
programming2C78B
118 Views, 4 Replies
Annoying! Is there a reason or formula I can change on this...IMO it should default to 0.
Please click "Accept Solution" if what I wrote solved your issue!
4 REPLIES 4
No, there is nothing you can do about that, sorry. Speaking in generalities, there are two camps of Fusion users; those who have all their tools prenumbered and leave them setup in their machines and Fusion libraries (static tool assignments) and those who start every job anew and load tools consecutively. It was decided that starting at #1 was the proper way to go, and I don't think there's any work being done to modify this behavior..
Seth Madore
I get that aspect of it, but I'm creating tools for my library, not inside a specific job. I want things to all start with 0 so they can take the next sequential spot in a job when they are actually being used.
Ah. It's an easy thing to fix, you can create all your tools, ignore the numbering and then select the entire library for renumber:
Seth Madore
I currently have over 120 milling tools in this library with some that truly do stay in the machine. Every once in a while I need to add a unique new tool and just find it annoying to have it become tool 1 (although I just did a dovetail cutter and it became tool 2? So this must be hardcoded somewhere)
Here's what stays in the carousel
edit: I just noticed that Tool 3 also snuck in there....see!
