which function can manufacture door on fusion?
ojh9VKRR
ojh9VKRR
Hi? I want to manufacture a door with fusion. I want to add a 180 degree swing head to the z-axis of an existing 3-axis cnc. What function of fusion manufacturing should I use to make the head rotate and mill two different planes? Thanks in advance.
programming2C78B
you just use Tool Orientation. The controller does the rest.
Please click "Accept Solution" if what I wrote solved your issue!
