Whenever I change the tolerance for a 3D Adaptive Toolpath, I get an error.
georgemurchison
georgemurchison
By default the tolerance is set to .004" and when I change it to anything else I get this error.
This is only happening on a 3D adaptive. 2D adaptive, Pocket, and other toolpaths seem to respond fine to changing tolerances. Any help would be greatly appreciated.
seth.madore
Would you be able to share your Fusion file here or privately?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Seth Madore
georgemurchison
Here's the file. It's a test file that includes the errored .001" tolerance 3D adaptive, a .004" tolerance adaptive with the same settings that has no error, and an equivalent 2d adaptive that is able to generate .001" tolerance with no error.
Camtech-CezayirYasa
Hi, you should check Tolerance and Smoothing settings. The faulty section will be separated in red during the operation.
georgemurchison
Both sections appear fine, but I get the error regardless.
seth.madore
I've opened up CAM-47310 to investigate this. For now, just run it at .003" tolerance. As it's a roughing toolpath not designed for finishing, you're going to need to use a finishing toolpath anyways. Just make sure your Stock to Leave is greater than .003"
Seth Madore
